Cloth Affector
Cloth Affector
Updated: 23 Jan 2025
Simulate Cloth with a Particle Mesh Deformer.
WARNING : This node is going to be deprecated, as its functionality has been replaced by the new, significantly improved, Cloth Deformer.
This node applies a cloth simulation to particles that were spawned from a Particle Mesh Deformer. Only particles created from a Particle Mesh Deformer will work with the cloth simulation because it requires information about connections between particles to create constraints. These are generated from the polygons and edges in the mesh parented to the Particle Mesh Deformer.
Position XThe objects position along the local x-axis.
Position YThe objects position along the local y-axis.
Position ZThe objects position along the local z-axis.
Rotation HeadingThe objects rotation around the local y-axis.
Rotation PitchThe objects rotation around the local x-axis.
Rotation BankThe objects rotation around the local z-axis.
Scale XThe objects scale along the local x-axis.
Scale YThe objects scale along the local y-axis.
Scale ZThe objects scale along the local z-axis.
PositionToggle inheritance of the Position from the parent.
RotationToggle inheritance of the Rotation from the parent.
ScaleToggle inheritance of the Scale from the parent.
World Position OnlyInherit the world position from the parent only, rotation and scale will be ignored. Overrides above properties.
Inherit TimeToggle inheritance of time from the parent.
StiffnessHow much the particles are resistant to deformation.
DampeningHow fast the particles slow down after movement.
