Triggerable Envelope Modifier
Trigger keyframed animations on a modifier.Updated: 4 Dec 2023
Trigger keyframed animations on a modifier.This node is used for triggerable animations on a specific value. Keyframes on the value property will only be played back until the trigger values condition has been met, where the value then plays back at a normal rate and holds its final value until the trigger is re-activated.
Parameter | Details |
Current Value | Shows the current value of the effect. Cannot be directly changed. |
Current Play Time | Read-only. The current play time value. |
Is Currently Triggered | Read-only. Indicates when the node triggers. |
Value | Base value to modify the output value with. |
Scale | Adjust the scale/range of the modifier. |
Operation | The operation to be performed on the targeted parameter.
These properties control the trigger conditions for when the animation should be activated.
Trigger | Triggers the animation set on the Value parameter. When this value is > 0.5, the animation is triggered. |
Instant Retrigger | Toggle whether the value can be re-activated immediately after its finished playing. |
Value | Input a value from another modifier to be modified by this node. | Math Modifier |
Trigger | Use an incoming value to reset the trigger. | Envelope Modifier |
