Speed Tracking Modifier
Calculates speed of movement in an input node.
This node calculates the rate of movement of the source node, connected via the “Tracked Node” input, and outputs it as a value.
Smoothing Adjust the amount of smoothing to applied to the output value.
Max Speed Set a maximum speed the modifier can read for a value.
Restore Values Toggle whether the values restore to 0. If unchecked, generated values incrementally add to the modifier value.
Tracked NodeThe node that you want to track the speed of.Null
