Smooth Envelope Modifier
Smooths incoming modifier values.
This node smooths incoming modifier values over time to create a smoother output value. Useful for removing noise from some sources.
Current ValueShows the current value of the effect. Cannot be directly changed.
ValueBase value to modify the output value with.
ScaleAdjust the scale/range of the modifier.
AttackControls the initial time between the current value to the peak.
DecayControls the time between the peak to the sustain level.
Hard Change ThresholdIf the value goes above this threshold, hard jump.
OperationThe operation to be performed on the targeted parameter.
Restore ValuesAttempt to move back to the current value to the input value more quickly.
ValueInput a value from another modifier to be modified by this node.Math Modifier
