Quantise Modifier
Quantise Modifier
Updated: 20 Aug 2025
Restrict a modifier value to multiples of a quantise value.
This node restricts a modifier value to be multiples of the Quantise Scale value. For example, a Quantise Scale value of 1.0 will restrict the input value to integers - 0, 1, 2, etc.
This node will always quantise a value to the closest quantise step. For example, with a quantise step of .5 an input of 2.49 will quantise to 2.0. An input of 2,50 or above will quantise to 3.0.
Value Shows the current value of the modifier. Cannot be directly changed.
Quantise Scale The current value will be rounded to the nearest multiple of this value.
ValueInput a value from another modifier to be modified by this node.Math Modifier
