MIDI Note As Value Modifier
Reads note values from a MIDI device.
This node reads note values from channels of a MIDI keyboard device so they can be used to control values on other nodes. Each note outputs a separate value, so each note can be isolated for separate effects.
The MIDI channel can be selected manually, or use “Listen For Channel” and make a trigger a note on the device and the channel will be picked up automatically.
You must first add the MIDI device in the Notch Midi Mapper. Go to Devices -> Audio Devices.
Current ValueShows the current value of the effect. Cannot be directly changed.
ChannelChoose which MIDI channel to use for the modifier.
CCSelect which control change to modify the channel.
Use Recorded ValueUses the recorded MIDI files, instead of the live input from a MIDI device.
Listen For Channel/CCListen for the incoming MIDI device.
Recording..Start recording changes in the current value, to save to as a sequence of keys on a newly created attribute.
ScaleAdjust the scale/range of the modifier.
OffsetOffset the current value of the incoming
OperationThe operation to be performed on the targeted parameter.
Recorded ValueThe currently recorded value being used.
