Input Selector Modifier
Select a modifier to pass through.Updated: 4 Dec 2023
Select a modifier to pass through.This node takes multiple input values and uses an index to select which modifier value to output.
| Selected Index | Select which of the outputs will be used. |
| Modifier Operation |
| Inputs | The nodes with outputs which will be selected between. | Math Modifier |
