Gradient Remap
Gradient Remap
Remap modifier values based on a custom gradient.
This node remaps incoming modifier values based on a user created gradient. Values outside of 0 and 1 are clamped.
Gradient Gradient used to remap values. Double click on the visual gradient to create a new node at that position. Click and drag on a node vertically to change the value at that position. Click and drag on a node horizontally to change the position at that value.
Modifier Operation What operation is done to the modified attribute.
  • Add : Adds the current value to where its input. Subtract, subtracts the current value to where its input.
  • Multiply : Multiplies the current value to where its input.
  • Replace : Replace the value where its input by the current value.
