Delay Value
Delays the output of modifier over time.Updated: 4 Dec 2023
Delays the output of modifier over time.This node delays the output of an input modifier by a time frame set by the Delay Time.
| Current Value | Shows the current value of the effect. Cannot be directly changed. |
| Value | Base value to modify the output value with. |
| Delay Time | Time in seconds the output value should be delayed by. Above 10, it will run out of space in its buffer and will no longer delay input values. |
| Operation |
