CSV/Table Read Modifier
Reads a value from a table cell for modifiers.Updated: 4 Dec 2023
Reads a value from a table cell for modifiers.This node reads in values from an imported table cell, and outputs it ready for use in a modifier system.
You can add tables in the Resource Panel via Interactive-> CSV/Text File
| CSV File | The table resource. |
| Read Index | In a 2D table, this is the column to be picked from. In a 1D list this is the index to pick. |
| Row Index | In a 2D table, this is the row to be picked from. |
| Selection Mode |
| Modifier Operation |
