Continuous Modifier
Continuous Modifier
Generates a continually increasing modifier value.
This modifier continually increments or decrements the targeted parameter value at a constant rate.
Speed The speed at which the modifier increases (per second)
Time Mode How the modifier updates in relation to the time code.
  • Use Deltas (Continuous/Looping) : The time runs based on the frame delta, loops when the play head loops, and the Playback Rate parameter may be animated.
  • Locked To Timecode : The modifier values are locked to the time code and the same time will always yield the same numerical value.
