Condition Modifier
Generate a modifier value when a condition is met.Updated: 4 Dec 2023
Generate a modifier value when a condition is met.This node outputs a set value once an input value meets a certain trigger condition.
| Current Value | Shows the current value of the effect. Cannot be directly changed. |
| Value | Base value to modify the output value with. |
| Threshold | Changes the threshold for what counts toward the modifier. |
| Trigger Mode |
How the value is modified, once the trigger condition is reached.
| Trigger Condition |
What conditions need to be met for the modifier to be triggered.
| Modifier Operation |
| Value | Input a value from another modifier to be modified by this node. | Math Modifier |
