Compare Text String
Compare Text String
Updated: 11 Sep 2024
Compares two text strings.
This node compares two Text String nodes.
When using the Simple compare mode, a return value of zero indicates that strings match otherwise a value of one is returned.
When using the Levenshtein Distance mode, the returned value is between zero and one, which indicate how different the input strings are.
The output is a numeric value that can be further processed with other modifiers, or directly connected to a parameter in another node.
Compare Mode Choose how to compare the input strings:
  • Levenshtein Distance : Calculate the difference using the Levenshtein distance technique. Outputs a value between 0 and 1.
  • Simple : Performs a simple string comparison to determine if the input strings are the same or not. Outputs a value of either 0 or 1.
Invert Invert the output value.
Text String 1The first input string to compare with.Text String
Text String 2The second input string to compare against.Text String
