Combiner
Combiner
Combine two modifier values with basic math operations.
This node combines two modifier inputs to create a new modifier output, using basic math operations. For more complicated operations, use the Expression Modifier.
Current Value Shows the current value of the effect. Cannot be directly changed.
Value 1 The first input value
Value 2 The second input value
Combiner Operation How the two inputs are to be combined:
  • Add : Add value 1 to value 2.
  • Add Saturated : Add value 1 and value 2, but clamp the output between 0 and 1.
  • Subtract : Subtract value 2 from value 1.
  • Subtract Saturated : Subtract value 2 from value 1, but clamp the output between 0 and 1.
  • Multiply : Multiply value 1 and value 2.
  • Min : Compare value 1 and value 2, and select the minimum value.
  • Max : Compare value 1 and value 2, and select the maximum value.
  • Divide : Divide value 1 with value 2. Negative values of value 2 are converted to positive before division.
  • Modulus : Perform value 1 modulus with value 2. Negative values of value 2 are converted to positive before modulus.
