Channel Extractor
Updated: 15 Jan 2025
Extracts a modifier value from a node.Updated: 15 Jan 2025
Extracts a modifier value from a node.This modifier extracts a single numerical value from another node. For some nodes, there are properties available specifically for the channel extractor node, like the Face Tracker or Hot Zone nodes.
Parameter | Details |
Current Value | Shows the current value of the effect. Cannot be directly changed. |
Source Envelope | Which parameter is to be extracted from the Source Node input. |
Operation | The operation to be performed on the targeted parameter.
Scale | Adjust the scale/range of the modifier. |
Offset | Applies an offset (post scale) to the calculated value |
Source Node | Source node from which the parameter is sourced. | Any node with numeric parameters |
