Subsurface Scattering Material
Updated: 21 Oct 2025
A subsurface scattering material.Updated: 21 Oct 2025
A subsurface scattering material.Subsurface Scattering is a technique that simulates how light penetrates the surface of translucent materials (like skin, milk, or wax), scatters within the material, and then exits at a different point. This effect creates a softer, more realistic appearance, especially for materials with depth, where light interacts below the surface.
This material needs the Path tracer node to function.
| Colour | The colour of the material. |
| Brightness | The brightness of the material. |
| Metallicness | Controls the metallicness of the material. |
| Normal Map Mode |
| Opacity Mode |
Controls the opacity mode of the material, and how it blends with the scene.
| Translucency |
| Absorption Colour | Colour to use for absorption. |
| Subsurface Weight | Weight of the subsurface scattering effect. |
| Subsurface Scatter Radius | Radius of the subsurface scattering effect. |
| UV Texture Filter Mode |
| Subsurface Colour Map UV | Select the UV for the Subsurface Colour Texture. |
| Subsurface Weight Map UV | Select the UV for the Subsurface Weight Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Reflections Mode |
| Shadows |
| Raytracing Settings |
| Polygon Sidedness |
| Glow | Controls the glow. |
| Vertex Colours - Apply To Alpha | Set how the vertex colours apply to the alpha of the mesh. |
This node has no inputs.
