Substance Material
Updated: 3 Jun 2026
Add an imported SBSAR material from Substance.
Updated: 3 Jun 2026
Notch allows the use of materials made with Substance Designer from Adobe. The Substance Designer Material once assigned to an object will behave like a standard Notch material. All options are identical, but with the ability to modify the texture on the fly according to the Substance parameters.
For more information about Substance Designer, visit their website.
By default, textures are not automatically cached. To do this, right-click on the node in the nodegraph and select Substance Material Options > Cache Substance Textures. A new material node will be generated with the textures from substance applied, and the textures will be added to the resource view.
It isn’t a necessity to cache the textures, this is only if you want to use one of the generated textures as a normal texture, and apply a filter to it for example.
| Substance SBS | Substance SBS File to generate textures from. |
| Substance SBS Preset | Preset in the Substance SBS file to use. |
| Output Width | Output width (pixels) of the generated textures. |
| Output Height | Output height (pixels) of the generated textures. |
| Colour | The colour of the material. |
| Brightness | The brightness of the material. |
| Normal Map Mode |
| Emissiveness | How much of a glow is emitted around the object. |
| Emissive Scattering | Controls how much Emissive lighting is scattered in the scene. |
| Emissive Lights Scene | Controls how much Emissive lighting contributes to lighting the scene. |
| Opacity Mode |
Controls the opacity mode of the material, and how it blends with the scene.
| Translucency |
| Diffuse Lightmap | Enables an input diffuse lightmap for the material. |
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| Emissiveness Map | Determines which parts of a material appear to glow or emit their own light. Brighter values cause the surface to act as a light source. |
| Metallicness Map | A grayscale map to define how ‘metal-like’ a surface is. White values represent pure metal, while black values represent non-metals. |
| Alpha Map | A grayscale map that controls the transparency of the material. Black areas are fully transparent, white areas are fully opaque, and gray values create semi-transparency. |
| Ambient Occlusion Map | Adds subtle, soft shadows to areas that are occluded from ambient light, such as creases and crevices. This enhances realism and adds perceived depth to the model. |
| UV Texture Filter Mode |
| Diffuse Map UV | Select the UV for the Diffuse Map Texture. |
| Emissiveness Map UV | Select the UV for the Emissiveness Map Texture. |
| Metallicness Map UV | Select the UV for the Metallicness Map Texture. |
| Alpha Map UV | Select the UV for the Alpha Map Texture. |
| Ambient Occlusion Map UV | Select the UV for the Ambient Occlusion Map Texture. |
| Subsurface Colour Map UV | Select the UV for the Subsurface Colour Texture. |
| Subsurface Weight Map UV | Select the UV for the Subsurface Weight Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit |
Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting.
| Reflections Mode |
| Shadows |
| Render Visibility |
Controls the object’s visibility to different types of rays in the renderer, which is useful for advanced effects.
| Raytracing Settings |
| Polygon Sidedness |
| Vertex Colours - Apply To Alpha | Set how the vertex colours apply to the alpha of the mesh. |
| Vertex Colours - Apply To Metallicness | Set how the vertex colours apply to the metallicness of the mesh. |
| Vertex Colours - Apply To Emissiveness | Set how the vertex colours apply to the emissiveness of the mesh. |
