Shadow Catcher Material
Updated: 4 Nov 2024
Captures shadows and generates a diffuse alpha blended material.
Updated: 4 Nov 2024
The shadow catcher node captures shadow information from lights cast on to the surface of an object that has the shadow catcher material applied to it.
The captured shadow information can then be rendered separately onto surfaces of a scene using the layers composite blend modes alpha channels. This will give you the ability to render shadows onto objects not in the scene - for instance on real-world objects or floors in AR projects.
The shadow catcher node is great for adding shadows onto surfaces for AR projects.
| Normal Map Mode |
| Opacity Mode |
Controls the opacity mode of the material, and how it blends with the scene.
| Diffuse Lightmap | Enables an input diffuse lightmap for the material. |
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| Alpha Map | A grayscale map that controls the transparency of the material. Black areas are fully transparent, white areas are fully opaque, and gray values create semi-transparency. |
| UV Texture Filter Mode |
| Diffuse Map -> AO |
A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color.
| Diffuse Map UV | Select the UV for the Diffuse Map Texture. |
| Alpha Map UV | Select the UV for the Alpha Map Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit |
Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting.
| Shadows |
| Shadow Catcher Colour | Set the colour of the material when “Shadows” is set to “Shadow Catcher”. |
| Shadow Catcher Blend | Blend amount of the shadows in the material. |
| Render Visibility |
Controls the object’s visibility to different types of rays in the renderer, which is useful for advanced effects.
| Raytracing Settings |
| Polygon Sidedness |
This node has no inputs.
