Metallic Material
Updated: 4 Nov 2024
Add a metallic material.
Updated: 4 Nov 2024
This node generates a basic metallic material, similar to the default material node but default metallic settings.
| Colour Map -> Specular Colour | Use the input colour map as the specular reflection colour. |
| Normal Map Mode |
| UV Texture Filter Mode |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit |
Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting.
| Reflections Mode |
| Shadows |
| Render Visibility |
Controls the object’s visibility to different types of rays in the renderer, which is useful for advanced effects.
| Raytracing Settings |
| Polygon Sidedness |
This node has no inputs.
