Diffuse Material
Updated: 4 Nov 2024
Add a diffuse rough material.
Updated: 4 Nov 2024
This node generates a basic diffuse material, similar to the default material node but without any specular settings.
| Colour | The colour of the material. |
| Brightness | The brightness of the material. |
| Normal Map Mode |
| Diffuse Lightmap | Enables an input diffuse lightmap for the material. |
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| UV Texture Filter Mode |
| Diffuse Map -> AO |
A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color.
| Diffuse Map UV | Select the UV for the Diffuse Map Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Shadows |
| Raytracing Settings |
| Polygon Sidedness |
This node has no inputs.
