Decal
Updated: 4 Nov 2024
Add decals to surfaces in the sceneUpdated: 4 Nov 2024
Add decals to surfaces in the sceneThis node projects images directly onto surfaces within a 3D environment. Instead of altering the original texture, the decal “layers” over it, allowing you to add visual effects like dirt marks, graffiti, impact marks, or other details. This approach makes adding visual details more flexible and resource-efficient, as it avoids the need to recreate or overload the original textures for each new visual addition.
| Mapping Type |
Controls how the texture is applied to the surface.
| Colour | Controls the base colour of the material. |
| Blend Mode |
Controls how the Decal blends with the existing object material.
| Blend Amount | Controls the strength of the blend effect. |
| Double Sided | Controls whether the Decal is applied to both sides of the mesh. |
| Normal Angle Threshold | Uses normals to determine the max angle at which the decal is applied. |
| Normal Angle Fade | Controls the softness of the edge of the decal based on the angle of the surface normal. |
| Texture Filter Mode |
Controls the filtering method used for the texture.
| Texture Wrap Mode U |
Controls the wrapping mode for the texture in the U direction.
| Texture Wrap Mode V |
Controls the wrapping mode for the texture in the V direction.
| Show Guides | Displays guides for lining up the decal. |
| Show Projection Bounds | Displays the projection bounds of the decal. |
These properties control the decal output mapping in UV space.
| Use Image Aspect Ratio | Uses the input image aspect ratio. |
| Flip X | Flips the texture on the ‘X’ axis. |
| Flip Y | Flips the texture on the ‘Y’ axis. |
| UV Scale X | Scale the mesh UV along the X axis. |
| UV Scale Y | Scale the mesh UV along the Y axis. |
| UV Offset X | Move the mesh UV along the X axis. |
| UV Offset Y | Move the mesh UV along the Y axis. |
These properties control where the deformer affects the geometry.
| Enabled | Enable falloff from the position of the deformer. |
| Shape |
Select which shape to use to draw falloff from.
| Shape Orientation | Along which axis the shape should be drawn. |
| Outer Range | The outer range from which the falloff is calculated from. |
| Inner Range | The inner range from which the falloff is calculated from. |
| Curve Power | How quickly the falloff drops to 0 at the outer falloff. |
| Invert | Invert the direction of the falloff. |
| Image | Input image to be used as a Decal. | Video Loader |
| Affected Object Nodes | Applies the Decal to the specified object nodes. | 3D Primitive |
| Excluded Object Nodes | Prevents the Decal from being applied to the specified object nodes. | 3D Primitive |
| Projection Transform | Copies the transform of the input node, and uses it to project the Decal onto the surface. | Null |
