Spot Light
Spot Light
Updated: 29 Jan 2026
Add a Spot Light
Add a Spot Light node into the scene.
Attach the Target Node input to any object, to have the light track that object.
Scale Y The objects scale along the local x-axis.
Scale Z The objects scale along the local x-axis.
Light Cone Angle Change the size of the area the light covers.
Light Inner Cone Angle Change the inner angle of the lights focus.
Falloff Mode Change how the light falloff is calculated.
  • Inner / Outer Radius (Legacy) : light falloff is calculated between the inner and outer radii.
  • Inv-Squared Distance (Physical) : the light falloff is calculated based on a physically accurate system.
Attenuation Distance Maximum distance the light reaches.
Falloff Power Change how strong the falloff for the light is between the Inner Attenuation Distance and the Attenuation Distance.
Penumbra Falloff Power How quickly the edges of the spotlight falloff.
Apply Specular Enable/Disable specular lighting.
Apply Diffuse Enable/disable diffuse lighting.
Projection Image Select an image to be projected from the light.
Projection Map Amount How much the image affects the projection.
IES Profile IES light profiles are published lighting profiles from manufacturers that show the lighting energy and patterns produced by their lighting systems. Notch is able to use these profiles to accurately replicate real-world lighting in its environments. A good resource site for these profiles can be found here.
Show Light Cone Show a cone in the scene to represent the lights current position and rotation.
Casts Shadows Toggle whether baked shadows are applied to the objects lit by the light node.
Shadow Softness Change how much softness is applied to the shadow edges.
Z Bias Increasing Z bias will improve the accuracy of grounding objects to their shadows.
Projection ImageAdd in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light. Only works when the Light Type is set to Spot.Video Loader
Multi-Source ControllerDeprecated feature.
