Sky Light
Sky Light
Updated: 29 Jan 2026
Add a dome of light to provide lighting from every angle. Best used with an enviroment image.
This node simulates a dome/sky light by surrounding the scene with a large number of shadow-casting spotlights positioned on the dome pointing inwards. This allows the skylight to be rendered efficiently, although it may still be too slow for real-time use in many scenes. To increase efficiency the spotlight shadow maps can be cached and only a subset updated per frame. This reduces render time significantly but reduces responsiveness to animation.
Omnidirectional When enabled, light emits from all directions inward. When disabled, light only emits from above.
Brightness Brightness of the light emit skylight.
Sky Dome Radius Radius of the skylight.
Visible Dome Brightness Scale Brightness of the visible skylight dome.
Apply Diffuse Enable / disable diffuse lighting for a Sky Light.
Apply Specular Enable / disable specular lighting for a Sky Light.
Apply Refracted Skylight Rays can move (refract) through translucent surfaces.
Translucent Raytraced Shadows Allows translucent shadows to be generated by Glass Materials.
Visible Sky Dome Generates a visible sky box around the light scene.
Lock Visible Sky Dome To Camera Locks the rotation of the sky dome to the active camera.
ObjectsSelect which objects should be affected by the skylight.3D Object
Environment MapAdd an environment map to control the colour of the skylight.Environment Image
