Area Light
Area Light
Add a light that emits from a rectangle.
This node emits light from a rectangular area, giving a soft light across a scene. An image texture can be input to emit light from the image based on a texture - useful for adding light from a screen, for example.
This light is great for producing a long flat light source.
To render soft shadows, Raytracing must be enabled in the root and in the node attributes.
Light Cone Angle Change the size of the area the light covers.
Light Inner Cone Angle Change the inner angle of the lights focus.
Double Sided Toggle whether light is emitted from both sides of the area light.
Visible Surface Toggle whether the Area Light Surface is visible to the light.
Visible Surface Casts Shadows Toggle whether the Area Light Surface can cast shadows from other light sources.
Normalise Intensity/Area Normalises the intensity of the light over it’s area.
Cast Shadows When Enabled, This light will cast shadows. Area Lights cant cast shadows with the Default Renderer or the Standard Renderer, so in those cases consider the Hybrid Renderer or careful SSAO usage.
Apply Specular Control whether this light applies specular light onto objects.
Apply Diffuse Control whether this light applies diffuse light onto objects.
Show Light Cone Show a cone in the scene to represent the lights current position and rotation.
Projection ImageAdd in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light.Video Loader
