Ambient Light
Add a light that applies to all surfaces equally.
This node emits a uniform light onto every surface in the scene. Useful for adding a little bit global illumination by raising the lowest levels of brightness in a scene.
This is a great tool for adding light to dark and shadowed areas.
| Colour | The colour of the light. |
| Brightness | How bright the light is. |
| Falloff Mode |
Change how the light falloff is calculated.
| Inner Attenuation Distance | Inner distance within which the light remains at full strength |
| Attenuation Distance | Maximum distance the light reaches. |
| Falloff Power | Change how strong the falloff for the light is between the Inner Attenuation Distance and the Attenuation Distance. |
| Projection Image | Add in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light. | Video Loader |
| Affected Nodes | Choose which nodes are affected by the light node. By default, all are affected. | 3D Object |
| Excluded Nodes | Choose which nodes are affected by the light node. By default, all are affected. | 3D Object |
| Texture Projection Node | Controls the direction the image is projected from, independant of the light. Only functions if an image is being projected from the light. | Null |
