TUIO Array
Updated: 17 Oct 2025
Generate an Array from TUIO data.
This node generates a transform array from TUIO data sent from a suitable external application that supports the TUIO protocol, via a network connection.
For TUIO to function, you’ll need a supporting application such as TUIOpad or TUIOdroid. This will be used as a source for the incoming TUIO Data. You will then need to make sure the host address and port number are the same as the target machines IP address and port number.
You can then use TUIO in much the same way as a standard Transform Array.
Only one Block/process can use a specific TUIO/OSC port number at a time. Either consolidate your effects into a single Block OR use different port numbers for each Block. Failing to do this will result in one or more of your Blocks not being able to receive TUIO data.
| Axis | Which axes for the generated shapes to generate on. |
| Apply Node Transforms To Array Elements Only | When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used. |
| TUIO Cursors | Allow the TUIO node to receive Cursor data. |
| TUIO Objects | Allow the TUIO node to receive Object data. |
| TUIO Blobs | Allow the TUIO node to receive Blob data. |
| Use TUIO Rotations | Use rotations from the incoming TUIO source. |
| Use TUIO Scales | Use scales from the incoming TUIO source. |
| Use TUIO ID's For Transform Indexing | Use the TUIO ID’s to index each point generated. This will attempt to keep cloned shapes consistent, but can lose points. |
| Flip X Axis | Flip the X axis of the incoming TUIO data. |
| Flip Y Axis | Flip the Y axis of the incoming TUIO data. |
| Ease Points On | Enable Point Easing in, so new points don’t immediately appear. |
| Ease Points On Mode |
| Ease Points On Duration | How long the points should take to fully appear. |
| Ease Points Off | Enable Point Easing out, so removed points don’t immediately disappear. |
| Ease Points Off Mode |
| Ease Points Off Duration | How long the points should take to fully disappear. |
| Easing Points Affects Point Scales | Allow the points to scale in size while easing. |
| Easing Points Affects Point Opacities | Allow the points to fade the opacity of objects while easing. |
Set the bounding dimensions of the incoming data, and the area within which points will be generated.
| Left | Set the left extent of the bounds. |
| Bottom | Set the bottom extent of the bounds. |
| Right | Set the right extent of the bounds. |
| Top | Set the top extent of the bounds. |
| 2D Bounds Source | To be used for the play area of the sensor. | Region Camera |
