Transform Array
Updated: 13 Dec 2024
Generate an Array using internal Notch sources.Updated: 13 Dec 2024
Generate an Array using internal Notch sources.This node is used to create an Array of ‘points’ from various other internal Notch sources. Specifically:
| Point Source | Effect |
| Sets of Nulls | Multiple Null nodes can be attached to the Point Source input to create an array with one element per Null. |
| Particle Root Nodes | Attaching a Particle Root Node to the Point Source input will generate an Array element for each particle in the particle system. |
| Blob Tracker | Attaching a Blob Tracker to the Point Source input will cause an Array element to be created for each detected blob. |
When used with particle systems, enable determinism or make sure the Particle Root Num Particles matches the live particle count as closely as possible.
The Transform Array node can also be used for initialising arrays that can be addressed via JavaScript.
The number of elements in the array may vary per frame, up to the defined maximum. The source of the transforms is typically a GPU buffer, so there is some latency in accessing them.
| Max Element Count | The maximum number of elements allowed in the transform array. |
| Low Latency (Slower) | Reduces the number of frames of latency by which elements are updated in the transform array. |
| Apply Node Transforms To Array Elements Only | When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used. |
| Point Sources | Can be either a set of Nulls, a Particle Root Node or Blob Tracker. | Null |
