Array Element Extractor
Extracts an individual point from an Array.Updated: 4 Dec 2023
Extracts an individual point from an Array.This node extracts an individual point from an Array Source based on its ID in the array index. Useful for extracting a specific element in an array, for controlling other elements in a scene.
| Point Index | Index of array data to extract. |
| Ease Point Scale On | Enable Point Easing in, so new points don’t immediately appear. |
| Ease Points On Mode |
| Ease Points On Duration | How long the points should take to fully appear. |
| Ease Point Scale Off | Enable Point Easing out, so removed points don’t immediately disappear. |
| Ease Points Off Mode |
| Ease Points Off Duration | How long the points should take to fully disappear. |
| Point Array | The Point Array is a user-controlled array of points. | Transform Array |
