Array Copy
Array Copy
Updated: 2 Feb 2026
Creates a copy of the points from an Array.
This node copies the data from an Array Source so that you can use the same Array in multiple places across a nodegraph. This is useful when doing interactive setups and you want a ’touch point’ to do multiple different things, such as render an object and emit particles.
The output is a transform array like any other – which may be used directly with a Array Cloner, or to clone other nodes within a Field System or Particle System.
Apply Node Transforms To Array Elements Only When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used.
Ease Points On Enable Point Easing in, so new points don’t immediately appear.
Ease Points On Mode
  • Linear,
  • Pow2,
  • Pow4,
Ease Points On Duration How long the points should take to fully appear.
Ease Points Off Enable Point Easing out, so removed points don’t immediately disappear.
Ease Points Off Mode
  • Linear,
  • Pow2,
  • Pow4,
Ease Points Off Duration How long the points should take to fully disappear.
Easing Points Affects Point Scales Allow the points to scale in size while easing.
Easing Points Affects Point Opacities Allow the points to fade the opacity of objects while easing.
Point ArrayArray of points used to perform operations based on.Transform Array
Bounding BoxOverwrite the bounds of the input ArrayRegion Camera
