Array Average
Array Average
Updated: 2 Feb 2026
Combines the points from an array to a single transform.
This node takes the points from an array and combines them based on the mode selected, to form a single output transform. Useful for extracting a particular transform in an array and using to control other elements in the scene.
Mode Change what the array node does with the list of array nodes.
  • Average : Averages all of the active points from the input transform system.
  • Closest To Reference Points : Uses the point closest to a reference point specified in the reference point input.
  • Largest : Uses the point with the greatest scale or the newest points if two points or more are the same size.
  • Newest : Returns the most recently added point.
Point ArrayArray of points used to perform operations based on.Transform Array
Reference PointUsed with Closest To Point mode, the point which is checked against.Null
