MIDI Keyboard Texture
Generates a texture based on a connected MIDI Keyboard.
This node generates a texture based on the output from a connected MIDI Device. Useful for visualising the inputs of a MIDI Keyboard, with standard attack/decay controls.
Position XThe objects position along the local x-axis.
Position YThe objects position along the local y-axis.
Position ZThe objects position along the local z-axis.
Rotation HeadingThe objects rotation around the local y-axis.
Rotation PitchThe objects rotation around the local x-axis.
Rotation BankThe objects rotation around the local z-axis.
Scale XThe objects scale along the local x-axis.
Scale YThe objects scale along the local y-axis.
Scale ZThe objects scale along the local z-axis.
ActiveEnables or disables the effect. Disabling the effect means it will no longer compute, so disabling a node when not in use can improve performance.
Preview In ViewportPreview the generated image as an overlay in the viewport.
WidthThe resolution of the generated image horizontally.
HeightThe resolution of the generated image vertically.
Update Time ModeHow the generator updates with relation to the timecode.
DeviceSelect an input device to use.
ChannelSelect a channel from the device to listen to.
AttackControls the initial time between the current values to the peak.
DecayControls the time between the peak to the sustain level.
Min ValueActs as a minimum threshold for extracting a range of values from the waveform.
Max ValueActs as a maximum threshold for extracting a range of values from the waveform.
Max ClampA maximum value which values will be clamped if they go above.
SpikinessAccentuates peaks in the waveform so they are sharper.
ScaleHow much the output values are scaled.
OffsetOffset all values output by the texture.
SmoothnessHow much smoothing is applied between differing values.
Falloff RangeRange in which the sounds data will be tracked.
ColourChange the colour of the generated image.
Blend AmountThe amount the generated image blends with the project, depending on the compositing mode chosen.
Blend ModeChoose how the image blends with the scene. See Blend Modes for details.
