Freehand Mask
Generates an image mask from hand drawn shapes.
This node generates a black and white mask sketched by clicking and dragging with the left most button in the viewport. When the right button is pressed the mask is cleared.
Notch must be paused to draw new masks.
| Preview In Viewport |
| Update Time Mode |
| Feather | Makes a blur which follows around the edges of the curve mask shape. |
| Editor Colour | Change the colour of the curve mask line, visualised in the viewport. |
| Blend Mode |
These properties contain an array of all the points included to create the mask.
| Contour | These properties contain an array of all the points included to create the mask. |
