Curve Mask
Curve Mask
Generates an image using user created shapes.
This node generates a mask by using a shape created using user created points.
With the scene paused and this node selected, you can create new points by left clicking in the viewport. Left click dragging moves the selected point around and right clicking a point will delete it. Using Ctrl left click dragging changes the curve of the line into and out of that point.
To close the mask you need to click on the first point.
Feather Makes a blur which follows around the edges of the curve mask shape.
Animate Points Allows the points to be keyframe animatable.
Editor Colour Change the colour of the curve mask line, visualised in the viewport.
Show Point Properties Shows the position and bezier controls for all the points individually in the property panel.
Displays attributes for each contour point when Show Point Properties is enabled.
Points # X Controls the X position of the contour point.
Points # Y Controls the Y position of the contour point.
Points # Tx Controls the contour handle in the ‘X’ direction
Points # Ty Controls the contour handle in the ‘Y’ direction
