Reaction-Diffusion
Generates a reaction-diffusion simulation for a field.
Performs reaction-diffusion simulation, using an image input as a seed.
This node simulates the Gray-Scott reaction-diffusion process, which can be thought of as a kind of fluid simulation with an extra step that creates organic-like patterns which grow out from seed points. Those points are created by sampling an input image, and seeds are created at the brighter parts of the image.
More information on the general topic of reaction-diffusion simulation can be found here The following image sequence shows how the pattern will grow out from a single point during the course of a simulation.
| Colour | The colour the reaction diffusion generates into the scene. |
| Amount | The amount of the input image to use as seed. |
| Pattern | How much the reaction diffusion attempts to join blobs into lines. |
| Rate | Speed at which the reaction diffusion spreads and attempts to fill the space. |
| Input Scale | Scale of the input images luminance to generate the reaction diffusion. |
| Softness | How soft the edges of the generated reaction diffusion are. |
| Parameter Image | Image used to generate a Ink from. | Video Loader |
