Procedural Emitter
Procedural Emitter
Emits ink into a field from procedurals.
This node emits colour/ink into a field using a procedural system.
A Procedural root must be connected to the Procedural Root input with a valid procedural generated for this node to emit anything.
Distance To Alpha Controls how the distances defined by the procedural system are converted into transparency values in the field - which is analogous to the density of the shape.
Emission Mode When to emit.
Colour The colour to emit.
Density Emission How density is applied to the system
Density The amount of density to emit.
Fuel Emission How fuel is applied to the system
Fuel The amount of fuel to emit.
Temperature Emission How temperature is applied to the system
Temperature The amount of temperature to emit.
Velocity Emission How velocity is applied to the system
Velocity The amount of velocity to emit.
Hardness Reduces the emission rate around the edges of the emission area to create softer looking edges.
Pyroclastic Displacement The amount of pyroclastic displacement.
P Noise Scale The scale of the fractal noise used to generate the pyroclastic displacement.
Procedural RootConnect a source procedural system to generate the field. A procedural node must be connected for this node to function.Procedural Root
Bounding BoxLimits the area that the procedural emitter will use.Bounding Box
Density NodesShading node input for controlling emitter densityFractal Noise
Temperature NodesShading node input for controlling emitter temperatureFractal Noise
Fuel NodesShading node input for controlling emitter fuel amountFractal Noise
Colour NodesShading node input for controlling emitter colourFractal Noise
Velocity NodesShading node input for controlling emitter velocityFractal Noise
