Primitive Emitter
Emits ink into a field using a primitive shape.
This node emits colour/ink into the field using the volume of a primitive shape.
| Primitive Type | Choose which object the field is emitted from. |
| Radius | Set the radius of the object. |
| Radius Inner | Inner radius of the object. |
| Size X | Size of the box along the X axis. |
| Size Y | Size of the box along the Y axis. |
| Size Z | Size of the box along the Z axis. |
| Height | Height of the object. |
| Thickness | Thickness of the object. |
| Volume | Emit inside the volume of the primitive or on its shell. |
| Emission Mode | When to emit. |
| Colour | The colour to emit. |
| Density Emission | How density is applied to the system |
| Density | The amount of density to emit. |
| Fuel Emission | How fuel is applied to the system |
| Fuel | The amount of fuel to emit. |
| Temperature Emission | How temperature is applied to the system |
| Temperature | The amount of temperature to emit. |
| Velocity Emission | How velocity is applied to the system |
| Velocity | The amount of velocity to emit. |
| Hardness | Reduces the emission rate around the edges of the emission area to create softer looking edges. |
| Pyroclastic Displacement | The amount of pyroclastic displacement. |
| P Noise Scale | The scale of the fractal noise used to generate the pyroclastic displacement. |
| Colour Ramp | Adds a colour gradient to the field. | Colour Ramp |
| Density Nodes | Shading node input for controlling emitter density | Fractal Noise |
| Temperature Nodes | Shading node input for controlling emitter temperature | Fractal Noise |
| Fuel Nodes | Shading node input for controlling emitter fuel amount | Fractal Noise |
| Colour Nodes | Shading node input for controlling emitter colour | Fractal Noise |
| Velocity Nodes | Shading node input for controlling emitter velocity | Fractal Noise |
