Mesh Emitter
Mesh Emitter
Updated: 12 Dec 2024
Emits ink into a field based on an input Mesh.
This node emits colour/ink into a field based on an input 3D object. The object is first voxelised, and the resultant voxels are used to contribute ink to the field.
Volume Emit inside the volume of the object or on its shell.
Emission Mode When to emit.
Resolution Resolution of the voxels used when generating the ink shape.
Object Colours Use the colours of the input object in the field emision
Colour The colour to emit.
Density Emission How density is applied to the system
Density The amount of density to emit.
Fuel Emission How fuel is applied to the system
Fuel The amount of fuel to emit.
Temperature Emission How temperature is applied to the system
Temperature The amount of temperature to emit.
Velocity Emission How velocity is applied to the system
Velocity The amount of velocity to emit.
Max Velocity The amount of velocity to emit.
Hardness Reduces the emission rate around the edges of the emission area to create softer looking edges.
ObjectObject used to generate a field based off of.3D Object
Colour RampAdds a colour gradient to the field.Colour Ramp
WeightmapShading node input for controlling emitter densityGenerate Weightmap
Density NodesShading node input for controlling emitter densityFractal Noise
Temperature NodesShading node input for controlling emitter temperatureFractal Noise
Fuel NodesShading node input for controlling emitter fuel amountFractal Noise
Colour NodesShading node input for controlling emitter colourFractal Noise
Velocity NodesShading node input for controlling emitter velocityFractal Noise
