Field - Field Emitter
Emits ink into a field from another input field.Updated: 4 Dec 2023
Emits ink into a field from another input field.This node emits colour/ink into a field by reading it from another input field.
| Blend Mode |
How the emitter blends into the field. See Blend Modes for details.
| Blend Amount | How much the input field blends with the current field. |
| Emission Mode | When to emit. |
| Colour | Tint the colour of the original field system. |
| Output Velocities | Toggles whether the velocities from the original field are output. |
| Velocity Scale | Scale the generated velocities from the source field. |
| Output Colours | Toggles whether the colours from the original field are output. |
| Field | The field to be added into the current field system. A node must be connected to this input for this node to function. | Field 2D Root Node |
| Colour Ramp | Adds a colour gradient to the field. | Colour Ramp |
| Density Nodes | Shading node input for controlling emitter density. | Fractal Noise |
| Temperature Nodes | Shading node input for controlling emitter temperature. | Fractal Noise |
| Fuel Nodes | Shading node input for controlling emitter fuel amount. | Fractal Noise |
| Colour Nodes | Shading node input for controlling emitter colour. | Fractal Noise |
| Velocity Nodes | Shading node input for controlling emitter velocity. | Fractal Noise |
