Velocity Affector
Velocity Affector
Applies a directional velocity to a field.
This node applies a directional velocity to the movement vectors of the field, pushing everything in the field along one direction.
Mode Change how the velocity affects the field.
  • Directional Velocity : Pushes the field along the local z axis.
  • Repel : Pushes the fields away from the affector origin point.
  • Attract : Pulls the field towards the affectors origin point.
Velocity Amount Scale the generated affector velocities.
Spread Angle Controls how much the spread there is from the field velocities generated.
Channels Which axes to apply velocity to
Velocity NodeA transform node that overrides the velocity direction and source position.Null
