Primitive Affector
Primitive Affector
Use basic primitives to affect the field.
This node uses basic geometric shapes to affect the field, by attracting or repelling the ink with respect to the selected primitive surface.
Primitive Type Choose which primitive shape is used for the affector.
  • Sphere : Use a sphere to affect the field.
  • Box : Use a box to affect the field.
  • Cylinder : Use a cylinder to affect the field.
  • Plane : Use a plane to affect the field.
  • 2D Grid : The field is affected by the edges of a 2d wireframe grid.
  • 3D Grid : The field is affected by the edges of a 3d wireframe grid.
  • 2D Noise : Uses a 2D noise field to affect the field.
  • Wireframe Sphere : The field is affected by the edges of a 3d wireframe sphere.
Velocity Mode Toggle whether the velocity attracts to the primitive or repels away from a primitive.
  • Repel : Push the field away from the primitive shape selected.
  • Attract : Pull the field towards the primitive shape selected.
Use Colours Allows the colour of the primitive to be blended into the field.
Radius The outer radius for which the affector is active.
Velocity Randomness Adds a randomness to the velocity of the field.
Velocity Scale Scale the generated affector velocities.
Weight How much the affector affects the field system.
Colour Weight The amount by which the colour of the primitive is blended into the field, if Use Colours is enabled.
Stickiness Controls how much the particle sticks to the surface of the shape once it reaches it.
