Points Affector
Points Affector
Use points to disturb a field.
This node affects a field by applying positional vortex forces created around points from a particle system, or vertices of a 3D object. This can be used to make a particle system “move through” a field and appear to affect it.
Velocity Amount Scale the generated affector velocities.
Point Falloff Distance The inner falloff radius from each point. Outside of this radius, the effect will no longer apply.
Point Falloff Power The sharpness of the falloff from each point. Higher values generate a stronger falloff at the outer falloff distance.
Radius The outer radius for which the affector is active.
Point SourceThe source of the point data.Particle Root Node
Procedural FalloffInput to use a procedural system to control the falloffProcedural Root
