Fluid 2D Affector
Applies a fluid simulation to a field.
This node applies a fluid solver to the velocities of the field system, creating eddies and swirls like a gas or liquid. This solver uses the grid-based Navier Stokes method, maintaining incompressible pressures using multiple iterations of a process over the field’s voxel grid, and can have a sizeable performance impact with high-resolution fields.
| Simulation Speed | Controls the speed of the fluid simulation. |
| Vorticity Confinement Scale | Controls the amount of vorticity confinement, which increases the number of small swirls in the fluid system. |
| Diffusion Amount | How much the field colours are diffused to neighbouring voxels. |
| Velocity Dampening | How much velocities are dampened and averaged across the field system. |
| Solver Iterations | How many times the fluid system solver is run. Higher values improve accuracy, but lower performance. |
