You're viewing an outdated version of the Notch Manual. View the latest version →
Derivative Feedback
Derivative Feedback
Applies a feedback effect to a 2D field.
This node applies a feedback effect to a 2D field based on the gradient of the colours at each point in the field. This creates the effect of the field spreading out from or pulling into sharp changes in the image - e.g. lines and corners. The process is applied iteratively, so larger iteration counts will cause the effect to be stronger per frame.
This node is only effective on 2D fields.
Amount The strength of the feedback effect.
Iterations The number of feedback iterations which are overlayed per frame.
