Fields
iconFields
Updated: 2 Feb 2026
Introduction #
A field is a grid of voxels, which simulation smoke effects using a mixture of ink a motion vectors. A voxel is a 3D pixel that contains the following data:
  • “Ink” - RGBA Colour information
  • “Movement Vector” - XYZ Vector to drive the ink
By holding colour / “ink” information in the voxel, we can render it like a drop of ink suspended in a liquid or a puff of cloud. By holding a vector of movement we can simulate complex fluid-like motions through the grid.
With every newly rendered frame, the simulation of the field is stepped forward. During this simulation step, each voxel calculates it’s movement vector by understanding how the movement of the surrounding voxels are affecting it. For example, if a voxel to the left has a movement vector pushing to the right it will transfer some of its movement into the voxels to it’s right. In this way, it simulates the real world of motion in liquids or gases.
Likewise, in each step of the simulation, a portion of the ink follows the direction of the movement vector.
The way voxels are rendered can vary greatly, allowing smoke, clouds or more solid forms.
There are four primary types of field nodes:
  • Emitters, these emit colour / “ink” into voxels in the grid.
  • Affectors, these add movement to the “movement vector” of voxels in the grid.
  • Rendering, these nodes visualise the voxels of the field controlling both their rendering and lighting.
You can also use the Movement Vector data from the field to affect particle systems using the Particle -> Affectors -> Field Affector node. This is very useful for fluid-like particle simulations.
Field systems starts with either a Field 2D Root or a Field 3D Root, and are built up with Emitter and Affector nodes, before finally being rendered to the camera with a Rendering node.
Fields are generally hooked into the Root node, although they can be applied to any node - they will still appear in the scene as long as there is a path to a Root node; they will inherit the transformation values of parent nodes.
Affectors
Affector nodes modify the velocities of voxels in a field.
Curl Noise AffectorCurl Noise Affector
Applies curl noise velocities to a field.
Derivative FeedbackDerivative Feedback
Applies a feedback effect to a 2D field.
Field AffectorField Affector
Applies a different field's velocities to a field.
Field FeedbackField Feedback
Blends the ink of a Field over time.
Field Procedural AffectorField Procedural Affector
This node affects a field's velocities by attracting or repelling it using a procedural's surface.
Fluid 2D AffectorFluid 2D Affector
Applies a fluid simulation to a field.
Image AffectorImage Affector
Uses an image to affect a field.
Points AffectorPoints Affector
Use points to disturb a field.
Primitive AffectorPrimitive Affector
Use basic primitives to affect the field.
Turbulence AffectorTurbulence Affector
Applies turbulent velocities to a field.
Velocity AffectorVelocity Affector
Applies a directional velocity to a field.
Vortex AffectorVortex Affector
Applies a rotational velocity to a field.
Collision
Add collision surfaces to a Field.
Mesh Collision AffectorMesh Collision Affector
Allows fields to collide with 3D Meshes.
Primitive Collision AffectorPrimitive Collision Affector
Allows fields to collide with primitive shapes.
Procedural Collision AffectorProcedural Collision Affector
This node allows fields to collide with procedurals.
Emitters
Emitter nodes spawn the colour/Ink that can be manipulated in a field system.
Field - Field EmitterField - Field Emitter
Emits ink into a field from another input field.
Image EmitterImage Emitter
Emits ink into a field from an input image.
Mesh EmitterMesh Emitter
Emits ink into a field based on an input Mesh.
Particle 2D EmitterParticle 2D Emitter
Emits ink into a field from particles.
Particle 3D EmitterParticle 3D Emitter
Primitive EmitterPrimitive Emitter
Emits ink into a field using a primitive shape.
Procedural EmitterProcedural Emitter
Emits ink into a field from procedurals.
Reaction-DiffusionReaction-Diffusion
Generates a reaction-diffusion simulation for a field.
Materials
Materials for field systems.
Field Cloud MaterialField Cloud Material
A 3D field material suitable for smoke and cloud volumes, which shades solely based on density.
Field Colour Ramp MaterialField Colour Ramp Material
Uses a colour ramp to colour a field system based on density or temperature. The field will fade through the colours in the ramp as the density/temperature get higher or lower.
Field Flame MaterialField Flame Material
A 3D field material suitable for fire / flames.
Field Pyro MaterialField Pyro Material
A 3D field material suitable for pyro / explosions.
Rendering
Rendering nodes visualise the field or control how it is rendered and shaded.
Field 2D RendererField 2D Renderer
Renders a field system as a volume.
Field 3D RendererField 3D Renderer
Renders a 3D field via path tracing.
Render To Object SurfaceRender To Object Surface
Apply the field to the surface of geometry.
Nodes
Field 2D RootField 2D Root
The root node for a 2D Field system
Field 3D RootField 3D Root
The root node for a 3D Field system
Field CacheField Cache
Caches a Field system to disk for consistent results.
Field Cache RendererField Cache Renderer
Playback a cached field simulation.
