Sound Deformer
Sound Deformer
Updated: 3 Feb 2025
Deforms geometry using the waveform from an input audio source
This node deforms a mesh using the waveform of an audio file or a live captured audio input. The waveform is processed using a set of parameters, allowing for greater control over how the sound is applied to the geometry.
  • Local : Deformations are calculated in the Local Space of the object, so transformations of the parent mesh will not affect the deformation.
  • World : Deformations are calculated in the World Space of the scene, so transformations of the parent mesh will apply the deformer differently depending on the mesh position.
Sound Sound file used to drive the effect.
Channel Which audio channel is used.
Frequency Band Sets the Band EQ to one of the given presets.
Band EQ Selects and weights the frequency bands to be used from the sound file.
Time Offset Offset the time the clones are modified from the time the waveform is at.
Threshold Changes the threshold for what counts toward the effect.
Attack Controls the initial time between the current values to the peak.
Min Value Acts as a minimum threshold for extracting a range of values from the waveform.
Max Value Acts as a maximum threshold for extracting a range of values from the waveform.
Clamp A maximum value which values will be clamped if they go above.
Spikiness Accentuates peaks in the waveform so they are sharper.
Scale How much the output values are scaled.
Smoothness How much smoothing is applied between differing values.
Mapping type Control how the sound displacement is mapped onto the geometry.
  • Planar : The sound is mapped to the surface from the planar y axis.
  • Spherical : The sound is mapped to the surface using a spherical projection.
  • UV : The sound is mapped to the surfaces UVs, which are then sampled for the mesh deformation.
FFT Sample Scale Scale the size of the waveform as it is applied.
Noise The amount of noise that is applied to the deformer.
Waveform Visualises the waveform of of the sound.
SoundUse the waveform from a given Play Sound or Sound Capture node.Sound Loader
