Point Deformer
Updated: 3 Feb 2025
Deforms geometry by using input points as a transform sourceUpdated: 3 Feb 2025
Deforms geometry by using input points as a transform sourceThis node is used to deform vertices using points from a particle system or the vertices of another 3D object. The closest points to each vertex are determined and a falloff calculated using the distance to those points, then displacement and colour modifications are applied to the vertex.
| Apply Mode |
Choose whether the deformer applies to the individual vertices or the mesh chunks.
| Transform Space |
Choose which transform space the deformer uses for deformation. Does not affect falloffs.
| Point Displacement Mode |
The method by which the points are used to displace the vertices.
| Blend Amount | Global override for how much the deformer affects the mesh. |
| Point Colour Mode |
How the points are used to colour the mesh vertex colours.
| Point Falloff Distance | The outer radius for each point where the deformer will no longer be effective. |
| Point Falloff Power | The sharpness of the falloff from each point. |
| Point Normal Direction Weight | Weights the effect of each point on the vertex by how much the mesh vertex normals points towards it. This allows points behind vertices to be ignored. |
| Colour Blend Amount | The amount the new colour is applied to the vertex colours. |
| Colour | The colour to apply to the mesh. Only functions with Distance enabled in the Point Colour Mode. |
| Time Mode |
How the deformer updates with relation to the timecode.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Point Source | Point source from which to deform the Mesh. | Particle Root |
| Mask Image | Use an image to mask out areas for the deformer to not function. | Video Loader |
| Generated Weightmap | Add a weightmap to vary the strength of the deformer across the surface. | Generate Weightmap |
