Particle Mesh Deformer
Updated: 3 Feb 2025
Deforms geometry by allowing Particle Affectors to apply to the mesh vertices
This node uses the forces from a particle system to affect the vertices of a mesh.
Connect Particle Affector nodes as children to the Particle Mesh node to have them apply to the parent mesh.
Physics Velocity Dampening Dampen the changes in velocity applied to the vertices for smoother movement.
Fixed Update Rate Enabled Force the deformer to update at a fixed rate.
Fixed Update Framerate Choose what framerate the deformer is updated at. Only functions with Fixed Update Rate enabled
Terminal Velocity The maximum speed the deformer can move at before the mesh is distorted.
Motion Smoothing How much motion smoothing is done to the deformer.
These properties control how the particle motion applies to the mesh.
Deformer Amount How much the particles affect the deformer.
Deformer Velocity Amount How much the particle velocities affect the deformer.
Apply After Subdivision Toggle whether the deformer is added before or after the object is subdivided.
Subdivision Level The subdivision level at which the deformer is applied. Subdivision Order must be set to After Subdivision to Function.
Weight ImageUse an image or video as a weightmap to control the deformation.Video Loader
