Noise Deformer
Noise Deformer
Updated: 3 Feb 2025
Deforms geometry using noise
This node displaces the vertices of a mesh using noise, fractal noise, a grid, and/or an input image or a video node.
  • Local : Deformations are calculated in the Local Space of the object, so transformations of the parent mesh will not affect the deformation.
  • World : Deformations are calculated in the World Space of the scene, so transformations of the parent mesh will apply the deformer differently depending on the mesh position.
Fractal Noise Amount The amount of fractal noise that is applied to the deformer.
Fractal Noise Scale The scale of the fractal noise that is applied to the deformer.
Fractal Noise Threshold The threshold for the fractal noise, below which the no deformation will be applied
Octaves How many times the noise generation is iterated.
Grid Amount How much the deformer uses a grid to displace the mesh.
Noise Amount The amount of noise that is applied to the deformer.
Texture Amount How much a video input into the node or an image selected in the image attribute affects the deformer.
Animation Speed Speed the deformer is animated at.
Grid NodeA node used to control the transformation values of the grid attribute.Null Node
