Volume Cloner
Volume Cloner
Updated: 8 Jan 2026
Generates clones which fill the volume of input geometry.
This node clones 3D objects in a regular 3D grid, generating clones in a shell around the mesh polygons. A 3D object node must be connected to the Source Objects input to define the voxelised shape the clones are arranged in for this node to be operational. The connected node must be either a 3D Object, a 3D Primitive or a Text node.
The connected mesh must also be active in the scene by being connected through a valid path to the root node.
Num Voxels X Number of voxels generated along the x axis.
Num Voxels Y Number of voxels generated along the y axis.
Num Voxels Z Number of voxels generated along the z axis.
Rotate Clone by Normals Rotate clones to match the normals of the volume.
Scale Clones By Voxel Size Scales the cloned objects to match the voxel sizes.
Rotation Stiffness How much clones resist rotating.
Scale Stiffness How much clones resist rotating.
Source ObjectsSource mesh to generate clones from. A mesh must be connected for the cloner to generate clones.3D Object
