Linear Cloner
Linear Cloner
Updated: 8 Jan 2026
Generates clone in a linear pattern.
This node generates clones between two defined transform positions. The clones between these locations will linearly blend between both transforms.
Num Clones Number of clones created.
Linear Size Mode .
  • Total Size : Transformation values are the total, each clone will be set at a division of this value.
  • Size Per Clone : Transformation values are added to each clone. The total value will be the transformation value times the clone amount.
Position X Min The minimum position the cloners will be generated from along the X axis.
Position X Max The maximum position the cloners will be generated from along the X axis.
Position Y Min The minimum position the cloners will be generated from along the Y axis.
Position Y Max The maximum position the cloners will be generated from along the Y axis.
Position Z Min The minimum position the cloners will be generated from along the Z axis.
Position Z Max The maximum position the cloners will be generated from along the Z axis.
Rotation Heading Min The minimum rotation the cloners will be generated from along their heading rotation.
Rotation Heading Max The maximum rotation the cloners will be generated from along their heading rotation.
Rotation Pitch Min The minimum rotation the cloners will be generated from along their pitch rotation.
Rotation Pitch Max The maximum rotation the cloners will be generated from along their pitch rotation.
Rotation Bank Min The minimum rotation the cloners will be generated from along their bank rotation.
Rotation Bank Max The maximum rotation the cloners will be generated from along their bank rotation.
Scale X Min The minimum scale the cloners will be generated from along the X axis.
Scale X Max The maximum position the cloners will be generated from along the X axis.
Scale Y Min The minimum scale the cloners will be generated from along the Y axis.
Scale Y Max The maximum scale the cloners will be generated from along the Y axis.
Scale Z Min The minimum scale the cloners will be generated from along the Z axis.
Scale Z Max The maximum scale the cloners will be generated from along the Z axis.
Reset Per Clone Transform .
